Sprayed primer on the fiberglass areas I've been working on to see where the pin holes and low spots are.
Smoothed the micro filled edges of the horizontal stabilizer. Generally smoothed the joined edges of the empennage tips.
The main power connection on the SkyTec starter is hot whenever the main contactor is closed and is not protected from accidental shorting. Checked with SkyTec and they suggested an MS25171-2S silicon nipple available from Aircraft Spruce, pn 11-03914. The nipple fits the starter flange well and fits tightly around the #6 power cable.
